Home » Audio » Speaker » 18" Subwoofer Horn - Opinions wanted!
Re: 18" Subwoofer Horn - Opinions wanted! [message #16081 is a reply to message #16077] Tue, 27 January 2004 08:47 Go to previous messageGo to previous message
Hi Adrian,
Looks good give it a try the only thing I'd try different is extending the lorn length a little more, at 1/4 wavelength it's only going to be operating as a horn down to about 43Hz. Anything below that it's going to be operating as a sealed box, you can see this in your first graph. Try to get the horn length out to about 2.75 meters, of course this will expand the mouth area also, this should get you to 30hz and room gain should make up the rest. But if you want to keep it that small you should be able to do it with the filters you suggested. Hope you have strong walls.
Bill W.
Previous Topic: Woofer tear-what to do
Next Topic: Paudio large woofers..
Current Time: Fri Nov 06 07:16:49 CST 2026
