Home » Audio » Speaker » A horn loaded bass 2 way for me?
Re: A horn loaded bass 2 way for me? [message #16052 is a reply to message #16030] Thu, 22 January 2004 07:38 Go to previous messageGo to previous message
Don't think you'll get 500Hz out of a 1" device. Resonance is usually around 800 to 1.5KHz, so I don't really see that happening. Especially consider distortion down this low from a 1" exit will be higher, and the smaller throat will increase throat distortion at these lower freq's. Most 1" horn flare's dont even provide loading to 500Hz; the JBL 2370 claims 630Hz full horn loading and its already a pretty large horn, but I'd probably want to run it 800Hz as minimum to keep distortion low. Get a 2" device though and you'll be set!
BMS 4590 :-)
Previous Topic: Directivity and modeling.
Next Topic: You can boil'm, fry'm, broil'm, gumbo'm, saute'm........
Current Time: Fri Nov 06 02:17:58 CST 2026
