Home » Audio » Speaker » New Speaker
Re: New Speaker [message #16012 is a reply to message #16003] Sat, 10 January 2004 12:37 Go to previous messageGo to previous message
Jeff Robinson is currently offline  Jeff Robinson
There are some obvious mistakes:
"The filter characteristics for each driver are determined in passive filter networks prior to each of the four amplifier inputs per speaker....For best transient and phase response, the mid-bass and mid-range band-pass filters are single-pole types, while the bass driver sees a 2 pole low pass filter at 22 Hz and the ribbon tweeter is crossed with 2 poles at 8 KHz. None of these filters uses feedback, positive or negative."
22Hz Low pass?????????? Does this mean the 98dB/W@1M 10" goes down to 22Hz? I don't think so, Tim! (220Hz seems more likely a choice for X-over freq. from a 15 {2P} to a 10 {1P}.)
Feedback in a passive filter?????????? NOT POSSIBLE!
Other than these quibbles it's an interesting read with minimized marketing hype.
Previous Topic: Open Baffle Bass - Why Not ?
Next Topic: I did it ! What did I do???
Current Time: Tue Nov 03 04:15:55 CST 2026
