Home » Audio » Speaker » New! Improved???
Re: Tweeter - Thank you, Wayne [message #15999 is a reply to message #15986] Tue, 06 January 2004 15:22 Go to previous messageGo to previous message
Looks very good, you said:
"The reflex driver is XO at 175 Hz to the mid-horn. Again the integration with the whole seems pretty good, but not as good as with the mid and top horns."
I don't know if you can do it on your x-over or not, but try delaying the reflex-driver to match the depth of the mid/hi horns and see what happens. If not you may have to play around with x-over freq. between the reflex and the mid-horn.
HTH
Bill W.
Previous Topic: vintage 8" fullrange speakers
Next Topic: Single driver speaker suggestion
Current Time: Tue Nov 03 10:57:07 CST 2026
