Home » Audio » Speaker » Re: Before anyone can answer...
Re: Before anyone can answer... [message #15995] Mon, 05 January 2004 21:03
Justin S is currently offline  Justin S
Usage will be for concerts and local Productions. I would like to generate 135 db's but am not picky as long as sound reproduction is at its best.
Frequency range will be 150Hz-20kHz
My midrange dirver is going to be a 15" b&c dirver
I plan on buying a premade horn for my compression driver; do you think that it will be easier to build with out or with premade horn for HF driver.
How can I get to adrian macks website?
Thanks so much for info.
Justin
Previous Topic: Anyone heard the Fostex Alnico F200A sold for $373 by madisound?
Next Topic: vintage 8" fullrange speakers
Current Time: Tue Nov 03 14:59:13 CST 2026
