Wayne Parham Messages: 19108 Registered: January 2001
Well, I don't want to be a Negative Nellie but I would not believe the power figure at all, not even close. I would also be suspicious of the SPL figure. I suspect the max power level is more like somewhere between 20 and 200 watts, and the SPL is probably around 105dB/W/M when put on a 90x40 horn. Those are specs of good compression drivers, so even if this thing is top notch, the numbers should fall in line.
