Home » Audio » Speaker » Help! Speaker Interference
Re: Help! Speaker Interference [message #15721 is a reply to message #15718] Mon, 29 September 2008 16:53 Go to previous message
Electrical noise is a problem that we all face at one time or another. In addition to the obvious noise coupled back onto the AC line, look for ground loops and bad shielding on preamp lines.
Here are a couple things to try:
1. Disconnect the inputs to the speaker's amps and see if the refrigerator and lamps still make the sound. If not, then noise is coupling into your inputs. In that case, you may have a bad signal cable that you can repair or replace to fix the problem.
2. Is the computer power plugged into the same outlet as the speaker amplifier power? If not, try plugging them into the same outlet. Use a barrier strip with multiple outlets if you need more sockets. This will ensure their grounds are connected and reduce the possibility of a ground loop.
Previous Topic: Coral speakers
Next Topic: Re: Array for centre channel?
Current Time: Sun Nov 08 20:30:12 CST 2026
