Home » Audio » Speaker » High frequency dispersion and driver size
Re: High frequency dispersion and driver size [message #15467 is a reply to message #15466] Fri, 09 March 2007 18:42 Go to previous messageGo to previous message
As a general rule of thumb, a driver's radiation pattern will narrow to about 90 degrees at the frequency where the cone diameter (or diaphragm dimension if non-circular) is equal to one wavelength. Cone break-up preserves a wider radiation pattern to a high frequency than if the cone were behaving as a rigid piston. A dome driver acts as an annular radiaton in breakup mode, which from what I understand also gives a wider pattern than rigid piston theory would predict but not as much so as a cone in breakup.
If you want to get into mathematics that will describe real-world loudspeaker behavior rather that idealized rigid pistons, I recommend "Audio Transducers" by Geddes.
Duke
Previous Topic: Cabs for dual Altec 416 8Bs
Next Topic: ART Arrays for HT?
Current Time: Fri Nov 06 05:56:40 CST 2026
