Home » Audio » Speaker » EV Eighteens
Re: EV Eighteens [message #15417 is a reply to message #15415] Wed, 08 November 2006 10:45 Go to previous messageGo to previous message
Depends on what your going to use them for, if there for PA, musical insturment or if you listen to your music at high volumes I'd get them re-done with the EV surrounds, there inpregnated cloth accordian surrounds. If you're using low power or just for normal stereo listening you can maybe use the foam ones like Wayne suggested. But then your T/S parameters won't match what EV spec'ed them at. Another thing to do is check around at your local recone shop.
HTH
Bill W.
Previous Topic: Jensen Imperial find
Next Topic: Jensen PM15A
Current Time: Thu Aug 06 09:01:32 CDT 2026
