Home » Audio » Speaker » Any opinions on AcouPower subwoofers?
Re: Any opinions on AcouPower subwoofers? [message #15307 is a reply to message #15304] Sat, 08 July 2006 18:44 Go to previous messageGo to previous message
gumby1 is currently offline  gumby1
The GR Research subwoofer kit does look pretty good. Could you describe more about your experience with it? What amplifier did you use with the GR Research? Was output inadequate for your needs? Did you use the Bully with a passive radiator? Ported? Sealed? How was the sound quality? What amplifier did you use with the Bully?
I hired a professional woodworker to build two Bill Fitzmaurice Autotuba subs. The output was pretty good, but I was not satisfied with the quality of sound. I also built two Rythmik Audio Servo subs in a sealed box. Cabinet was 2 inches thick with bracing and net internal volume of two cubic feet. Sound quality was about the same as the North Creeks, but output was not adequate even with the gain modified by Rythmik. Rythmik Audio does have good service if you happen to do business with them.
Previous Topic: coaxial driver
Next Topic: ultimate line array
Current Time: Wed Nov 04 22:57:41 CST 2026
