Home » Audio » Speaker » Dynaco A25
Huh.. woofers are exactly 9.75".. [message #15248 is a reply to message #15247] Mon, 27 March 2006 15:27 Go to previous messageGo to previous message
marc-homeslice is currently offline  marc-homeslice
Just measured the diameter from basket frame across. I'm suprised.. the box seems so much smaller than my AR11s and their woofer is maybe 10, 10.25" max.
Wow.. you're right -- just be sure that the new driver is the exact same if you want to use the old box. I will look into possibly swapping in new drivers (why not, so many have been updating the tweeters to Seas or Morel).
Switching caps and playing with the xovers shouldn't be too tricky; do they recommend using the old boxes with the same aperiodic vent (sorry if you guys posted this above).
I love the way mine sound, but there's little doubt that much has been improved in terms of driver design in 35 years.
Previous Topic: AudioRoundTable Archive
Next Topic: Need help with my first build project
Current Time: Fri Nov 06 00:37:58 CST 2026
