Home » Audio » Speaker » Woofer choice and attenuation
Re: Woofer choice and attenuation [message #15133 is a reply to message #15132] Tue, 06 December 2005 09:39 Go to previous message
Yep, looks like you'll need to attenuate the tweeter. A simple fixed resistor voltage divider with high quality resistors should suffice. It will also serve to damp the crossover, providing a more constant load.
Previous Topic: Black Hole 5 vs. Sonic Barrier - Any opinions?
Next Topic: Earl - Which sub do you use?
Current Time: Mon Oct 12 12:41:10 CDT 2026
