Home » Audio » Speaker » Black Hole 5 vs. Sonic Barrier - Any opinions?
Re: Black Hole 5 vs. Sonic Barrier - Any opinions? [message #15129 is a reply to message #15128] Tue, 29 November 2005 22:42 Go to previous messageGo to previous message
Cuppa Joe is currently offline  Cuppa Joe
Although it's a tardy response, better late than never! The main problem with fiberglass insulation is the DUST. The aforementioned turbulance can cause fiberglass particles to impact the back of the cone, or to (eventually) find their way into the driver's voice coil. Someone (don't remember who) makes a 1" thick, unbacked roll of fiberglass insulation, which is lightly spray-coated with a sealant to prevent dusting. It's still not as good as polyfill, but it's a lot cheaper, and is still a vast improvement over the ol' R19!
Previous Topic: need data on gauss hf 4000
Next Topic: Woofer choice and attenuation
Current Time: Fri Nov 13 05:59:59 CST 2026
