Home » Audio » Speaker » Black Hole 5 vs. Sonic Barrier - Any opinions?
Re: Black Hole 5 vs. Sonic Barrier - Any opinions? [message #15126 is a reply to message #15125] Thu, 10 November 2005 00:40 Go to previous messageGo to previous message
I bought some Sonic Barrier once. Maybe I got a bad batch, but the stick-um on it was pretty weak, and it started falling off the enclosure walls before I had finished installing the drivers.
Can't comment from experience on the effectiveness of either one in a subwoofer application, but one of the manufacturers I represent uses Black Hole 5 in the "hot-rod" versions of his full-range speakers.
In a subwoofer enclosure, I'd be inclined more towards making the enclosure walls super-stiff, to drive the resonant modes above the subwoofer's passband, and then putting some polyfill in the box to eat up residual lower midrange energy. If the crossover is low enough and steep enough, you might not need any polyfill. But I don't think either Black Hole 5 or Sonic Barrier is going to do much at subwoofer frequencies.
Duke
Previous Topic: need data on gauss hf 4000
Next Topic: Woofer choice and attenuation
Current Time: Fri Nov 13 06:00:54 CST 2026
