Home » Audio » Speaker » Bypassing speakers transformer
Re: Bypassing speakers transformer [message #15094 is a reply to message #15093] Wed, 31 August 2005 04:21 Go to previous messageGo to previous message
Sounds like the speakers were used with 100V constant voltage distribution transformers. If you're able to wire to the voice coil directly, and you're sure it is an 8 ohm voice coil, then you're all set. Disconnect the transformer and connect direct.
Is it a single driver or does your speaker have a crossover?
Previous Topic: lowther drivers in cabinets
Next Topic: Two horn theory papers
Current Time: Fri Oct 16 17:15:36 CDT 2026
