Home » Audio » Speaker » IN WALLS ???
Re: IN WALLS ??? [message #15026 is a reply to message #15025] Sat, 04 June 2005 12:01 Go to previous messageGo to previous message
How much depth do you have to work with? I'll be finishing my basement in a few months, and I going to run into the same issues. Luckily, the walls will be pulled out about 10" from the foundation; so, I am considering using the Pi 1s in the walls beside the TV and possibly the ceiling. The bass will be filled in by a dedicated sub.
If you are going between 2x4 studs and have limited depth, look over at the Parts Express "Tech Talk" forum and see what these guys are using for smallish 2-ways. A small, decent sounding 2-way can be built for
Previous Topic: Finished At Last
Next Topic: Initial imprssion of the Audio Nirvana 6,5
Current Time: Fri Nov 27 11:27:40 CST 2026
