Home » Audio » Speaker » Image perception
Re: Image perception [message #14981 is a reply to message #14977] Sat, 21 May 2005 18:16 Go to previous messageGo to previous message
I can try to provide some experience. What I get with the 45 deg. toe-in and about 10 feet back equidistant from each speaker(I measure the distance with a ruler). The speakers are 3 ft in front of the back wall and I sit in the apex of a bay window with drapes.
The sound narrows as you pull forward until at about 6 ft the players are clearly defined and static, like a 2d representation very clearly defined but spread slightly wider than the speakers 8ft seperation. As you pull back to about 10 ft + the the sound meshes and players bleed into the space occupied by each other and fill a broader space; more like you hear at a classical music concert hall.
Further back into the room at about 14 ft the soundstage widens and broadens but the different instruments can begin to change orientation; ie, they might shift their place as the notes change.
Hope this is of some use.
Previous Topic: power tapering and l-pads
Next Topic: epiphany model 6-6 /12-12
Current Time: Tue Nov 03 17:41:15 CST 2026
