Home » Audio » Speaker » Questions on sub-woofer amps
Re: Questions on sub-woofer amps [message #14947 is a reply to message #14926] Wed, 27 April 2005 21:30 Go to previous message
Its there to artificially boost the low end response. Especially for sealed box subwoofers.
If its the typical PE/Apex/Stryke style plate amp, it uses an EC SK 2nd order HP filter. Essentially its a high-Q 2nd order highpass filter. When Q>1.0 it forms a filter peak which is what forms the "bass boost", or EQ. Modifying it is a matter of replacing two resistors on the preamp board, and using simple textbook formula's to choose any Q and Fc you want.
It is possible to design a subwoofer which EQ is an integral part of the design to form flat response, but EQ used disappropriately always makes a bad result.
Previous Topic: An ebay item to keep an eye on
Next Topic: Are there any active speakers with tube amplifakshun?
Current Time: Wed Sep 23 08:40:18 CDT 2026
