Home » Audio » Speaker » Alnico verses ferrite verses neodymium
Re: Alnico verses ferrite verses neodymium [message #14784 is a reply to message #14712] Thu, 18 November 2004 12:37 Go to previous messageGo to previous message
Ragnar Lian is currently offline  Ragnar Lian
Sorry, I have not noticed this group. But here I am, still alive. Of economical reasons I have changed from loudspeakers to medical actuators, but the same physics are ruling.
I do not know the reason for previous question, but I guess it is caused by an old JBL slogan "the alnico sound". The sonic difference alnico-ferrite is caused by more parameters.
The physical shape of the normal ferrite magnet system is close to whorst case, causing many distortion mechanisms. Also ferrite magnets are relative "soft". When you put a current through the voice coil, it acts at an additional magnet, modulating the main magnet. Alnico have a sharp break point, at the right side magnet are "stiff", and on the wrong side, it is demagnetized. This was the main problem when we had the first generations og high power audio amplifiers (Dynaco Mark 3 and Stereo 120). Either it was OK, or the speaker was significantly and permanetly degraded .
For ferrite, sound was normal more or less bad, but speaker was not demagnetized.
I have made tests and simulations on 3 differend magnet systems having same linear movement and same Bxl, locking the coil in mid position, applying 10 amp current, and observing force in + and - direction. Result can vary, but the metioned numbers is representative. Of course, this is static properities, and dynamic properities may be different. I have not had time for further investigatemens, but I am an okd guy, and there shall also be lot of work and fun for younger people, come along !
OOPS ! I do not yet know this forum, and have to find its form.
I like to play ping-pong, and will now see if something happends
Previous Topic: Japanese only fostex
Next Topic: Fountek ribbons
Current Time: Fri Oct 16 14:05:53 CDT 2026
