Home » Audio » Speaker » speaker ohms
Re: split impedance [message #14707 is a reply to message #14703] Mon, 06 September 2004 07:27 Go to previous messageGo to previous message
True, but as long as the load impedance is within the amps ability to drive it the amp doesn't care. Differing impedances would bother a constant current amp, so amps are constant voltage devices for just that reason. Besides, impedance is always a nominal figure. The typical in-use impedance of an 8 ohm woofer actually runs from a low of perhaps 5 ohms to a high of 50 ohms or more, depending on the frequency at which you measure.
Previous Topic: Doppler distortion
Next Topic: Cats vs Speakers
Current Time: Sun Oct 25 02:00:13 CDT 2026
