Home » Audio » Speaker » Taking a wild guess here about cross-over design
Not that I know nuthin' about nuthin', but... [message #14657 is a reply to message #14655] Sun, 01 August 2004 07:12 Go to previous messageGo to previous message
Not that your hypothesis is impossible, but I find it extraordinarily implausible. This is a commercial product – what could possibly be more inconvenient than a porcelain as a connector for anything other than a light bulb?
I looked up a DIY ESL amplifier design from the same era (1968). In that design the author used light bulbs “to equalize the voltage to the capacitors” in the high voltage section of the output.
After reading that, I remembered that Nelson Pass has an amp design that uses four standard base light bulbs in some sort of regulation scheme.
It may not represent an component of a crossover section as I originally thought it might, but I find it very difficult to believe that it’s intended to terminate the panel leads either.
Previous Topic: compression horn tweeter
Next Topic: "Distributed Mode Radiation"
Current Time: Wed Nov 04 01:25:55 CST 2026
