Home » Audio » Speaker » Speaker Question
Re: Speaker Question [message #14585 is a reply to message #14583] Wed, 14 April 2004 20:32 Go to previous messageGo to previous message
Inexpensive so-called DJ speakers are typically variants on inexpensive live sound PA speakers, and while they can play loud they for the most part use inferior components and sound quite terrible. To have something of that variety worth owning new be prepared to double your budget.
For what you want to spend go used; a good source is local musical instrument stores, where you can try before you buy and possibly even get a basic warranty. There's plenty of them out there, from bands that either traded for better or broke up and pawned their gear.
Previous Topic: CHoices! (basshorns)
Next Topic: Horn Cab for the Lab 12
Current Time: Thu Nov 05 01:59:29 CST 2026
