Home » Audio » Speaker » Can't reproduce a square wave
Re: Can't reproduce a square wave [message #14543 is a reply to message #14542] Wed, 17 March 2004 20:55 Go to previous messageGo to previous message
Tom Danley is currently offline  Tom Danley
Hi Wayne
It can be argued as you have in the past that in the home, a sound reproducer that preserves the waveshape of the input signal is not strictly necessary.
In sound cancellation however the exact waveshape must be produced if it is to cancel an offending noise. I have built transducers for this application as well and am familiar with what is involved.
It would seem the question of how much a speaker can screw up waveshape or corrupt the time element and still be listenable is separate from the conditions needed for preserving a complex input.
Your "creating a differentiated pulse" issue with this at low frequencies is based on an incorrect assumption. Radiating into space, the radiator motion (for a direct radiator) that produces an acoustic square wave is a triangle motion, not a physical square wave.
It is the radiator volume velocity that produces pressure and as long one is about 10 X higher than the low cutoff (owing to the requirements to have a good looking square wave), there is no problem going down in frequency and radiating a "square wave" assuming the flat pressure and phase region had sufficient bandwidth.
(at least from the stand point of having made acoustic sources systems which preserve waveshape down into the single digits)
Cheers,
Tom
Are you going to NSCA?
Previous Topic: Effects of a low pass notch filter on BR versus TL: speculations
Next Topic: Re: Can a notch filter improve phase lag?
Current Time: Mon Oct 05 11:10:44 CDT 2026
