Home » Audio » Source » EAC Question
Re: EAC Question [message #14430 is a reply to message #14422] Thu, 13 September 2007 18:11 Go to previous messageGo to previous message
Fred,
The last time I tried writing CD's from WMP, the only output I could get was Red Book. That being the case, if your input was WMA lossless, then your output should have been bit-for-bit identical to the original CD. Also, IIRC EAC would only make one-for-one, CD to CDR copies. I was trying to make some CDR's in 192k MP3 and neither WMP or EAC would do it. I believe I used Audio Grabber to make the MP3 CDR's.
OK. I stand corrected. I WMP 11, go to the extra options under the burn tab and make sure that "do not"convert" is checked. Your output should be Red Book.
Another thing that you might try is burning each track as a data file. The intermediate file will be WAV regardless of what the input is and the copy will be Red Book.
Bob
Previous Topic: Minidisks?
Next Topic: converting any files...
Current Time: Thu Nov 05 07:26:59 CST 2026
