Home » Audio » Source » HD Radio
Got It [message #14367 is a reply to message #14363] Tue, 26 December 2006 13:57 Go to previous messageGo to previous message
Fry's has restocked after the Christmas rush and I picked up the Sangean tuner today. There's the usual problem you get when you play a tuner through a high resolution audio system - when you turn the volume up you hear some background noise, but the sound quality at normal listening levels is good. The output level of this tuner is a bit higher than the typical CD player, which means you listen at a lower volume setting. The sound is on the bright side, so if you have a choice avoid bright interconnects. But for only $199 it's a good choice for listening to your favorite station at a background level.
Previous Topic: converting any files...
Next Topic: vintage table?
Current Time: Sat Nov 21 03:24:50 CST 2026
