Home » Audio » Source » Bypassing Output Stage?
Re: Bypassing Output Stage? [message #14232 is a reply to message #14230] Wed, 20 July 2005 15:09 Go to previous messageGo to previous message
That's what John Swenson does with his Toshiba 3950/60 mod. The signal path is tapped into just before the caps that connect the DAC to the filter / analog stage Op Amp. The improvement is phenomenal. The output is reduced by about 2 to 4dB, and the impedance is fairly high so you need to use an active preamp or integrated amp.
Previous Topic: Operetta's/Dominic
Next Topic: CS508 Lift problems resolved...
Current Time: Thu Nov 05 23:51:03 CST 2026
