Home » Audio » Source » ART DI/O mods?
Re: ART DI/O mods? [message #14046 is a reply to message #14045] Fri, 12 December 2003 23:51 Go to previous messageGo to previous message
Hi Wayne,
It's a small single tube DAC. You can take the digital signal from any crappy sounding cd player and just use it as a transport. Then the DAC sends analogue signal into your preamp. I've heard better transports and dac before but the increase in performance was small and they cost literally thousand's. The DI/O is around a hundred bucks.
Anyway the problem if it has one is that it's suited for balanced line and the signal is pretty hot. I'm more than happy to take it apart and replace some parts. I'm just not the guy to re-engineer the thing! Pick one up, they're cheap, you'll love it.
Bill
Previous Topic: Marantz TT320 turntable info needed
Next Topic: Denon DP-25F belt fell off, help!
Current Time: Thu Sep 24 04:13:59 CDT 2026
