Home » Audio » Source » How can I adjust the tone arm so it does not miss the edge of the record?
Re: How can I adjust the tone arm so it does not miss the edge of the record? [message #13757 is a reply to message #13756] Tue, 31 March 2009 13:11 Go to previous messageGo to previous message
david is currently offline  david
What do you think of this?
nat
The 45/33 switch should actuate a mechanism that selects the correct set down point for each type of record. Probably its stuck because of dried grease, and as you have already discovered, the set down adjustment screw only fine tunes the point. There may be a manual for your Garrard or a similar vintage one, and it could lead you to the actual part that needs loosening up.
dac10012
I suspected as much. And it takes a great deal of force to move the lever between 33 1/3 and 45. I don't have a manual, of course. I am handy though. Is this something that could be fixed with Wd-40 or do I need some sort of special grease? I haven't even looked at the underside to see if the parts are easily accessible or I may have to remove the whole mechanism from the base first? Thanks again.
Previous Topic: Denon DP-37F
Next Topic: Need help w/ Pioneer PL-L70
Current Time: Thu Nov 05 19:09:54 CST 2026
