Home » Audio » Source » 100,000 ohms!
Re: 100,000 ohms! [message #13648 is a reply to message #13647] Mon, 11 February 2008 12:10 Go to previous messageGo to previous message
Since the load sets damping of the coil, it will surely impact the sound. I would guess a higher impedance load would tend to increase output at the stylus resonance and a lower impedance load would decrease it, but that's just a guess. Might make a little more bass with higher impedance and a little less bass with lower impedance. Probably change the overall output level too.
The standard load is 47KΩ and most phono stage amps have this across the input line. Did you remove that resistor or did you add 100KΩ across the line, making total impedance 32KΩ? I'm wondering if the idea is to reduce damping by replacing the 47KΩ load with a 100KΩ load, or if it's to increase damping by adding more shunt resistance, lowering the load to 32KΩ.
Previous Topic: TEAC V-8000s vs TEAC V-8030s
Next Topic: Aiwa PX-E850 motor problem
Current Time: Wed Nov 04 19:22:54 CST 2026
