Home » Audio » Source » The Doctor Is In
Re: The Doctor Is In [message #13620 is a reply to message #13619] Sat, 05 January 2008 11:40 Go to previous messageGo to previous message
The Disc Doctor brushes are from Elusive Disc, I think they also have RRL that Music Direct calls Mobile Fidelity. Then there's L'Art du Son, Bugtussell, Walker (I know an industry guy who's a good friend of Lloyds and calls him "Lunatic Walker") Prelude, etc.
I've been using strips of 'paint pad refill' on either side of the 1/8" slot I cut in the vacuum crevice tool. Seems soft enough but the DD brushes came with a set of refill pads. I'm going to use them instead.
Glue'm on the crevice tool with Carpenters or Plumbers Goop, heavy bodied contact adhesive so good it'll glue your side view mirror back on the car in Winter. Ask me how I know!
Then all's ya need is a broken turntable to support the record whilst cleaning or better yet a working direct drive that'll turn the record for ya.
Take a look at the Loricraft site for their cleaning tutorial. Best I've seen; all the info is backed up by my experience. No way I'll ever afford one. The main quibble they have with cheaper RCMs with cleaning wands like the VPI is the uneven suction on warped records. My handheld tool appears to negate that.
You will hear a difference and not just less noise but a resulting improvement in fidelity from, I suppose, the higher S/N.
Previous Topic: pc audio output level?
Next Topic: total newbie pls help w/ setting up Pro-Ject Debut III Phono SB???
Current Time: Fri Nov 13 09:22:43 CST 2026
