Home » Audio » Source » Technics SL-220 Very low volume output!
Re: Technics SL-220 Very low volume output! [message #13540 is a reply to message #13539] Thu, 11 October 2007 14:47 Go to previous messageGo to previous message
Sounds like you need a phono stage. The one you mentioned will work just fine. There are others too, so look through the posts in the link below:
As for the ground connection, it is used to reduce hum. If your phono preamp has a ground lug, hook it there. If not, connect it to the chassis of your receiver.
Previous Topic: Marantz SLT 12
Next Topic: Gemini tt02 problem
Current Time: Sat Oct 17 00:19:02 CDT 2026
