Home » Audio » Source » Turntable help
Re: Turntable help [message #13526 is a reply to message #13511] Thu, 27 September 2007 17:23 Go to previous message
Dominic is currently offline  Dominic
I think that, in the absence of specs, the best rule for bearing adjustment is “if you can feel the play than it needs to be tighter.” This goes for just about all bearings; cars, turntables, tanks, planes. The rule I learned was the “quarter turn” rule. tighten the bearing just enough until you feel pressure, that is, the top race against the bearing, then back off a bit. A bit can be from 1/8 to 1/4 or what feels good. if you back off enough to feel play again then that's too much. Good luck.
Previous Topic: Mic Preamp
Next Topic: sony ps-lx350h question
Current Time: Fri Oct 23 19:07:49 CDT 2026
