Home » Audio » Source » Earth Wire
Re: Earth Wire [message #13324 is a reply to message #13323] Wed, 14 March 2007 12:42 Go to previous messageGo to previous message
If you don't connect the ground wire, then you'll hear a lot of hum when the phono input is selected. You can connect it directly to the chassis of the amp, but if there isn't a specific chassis ground connection, then chances are your amplifier doesn't have phono inputs. If that's true, you'll need to get a phono stage preamp. Otherwise, volume will be very low - You'll barely hear the record even at full volume.
Previous Topic: Recording From Turntable To Computer
Next Topic: I want to be converted!
Current Time: Fri Nov 06 07:45:26 CST 2026
