Home » Audio » Source » unstable platter
Re: unstable platter [message #13241 is a reply to message #13235] Mon, 08 January 2007 15:04 Go to previous messageGo to previous message
Not many scratchers hang out here. This place is mostly for audiophiles.
That said, I wouldn't expect much play in the platter bearing. It's basically a zero-clearance fit. The tolerance is so tight on a good turntable that there isn't even room for a film of oil. There doesn't need to be any room for heat expansion, and you don't want any chatter. So the clearance in this bearing should be extremely close.
Previous Topic: quarter inch tape deck question
Next Topic: Clearaudio Aurum Beta S
Current Time: Thu Nov 19 09:26:04 CST 2026
