Home » Audio » Source » Thorens TD-150 hum
Re: Ground or bad connection [message #13199 is a reply to message #13198] Fri, 08 December 2006 11:21 Go to previous messageGo to previous message
Bill Agee is currently offline  Bill Agee
It sounds like there is a ground for the chassis and a shield for cart leads, and these two are not connected together is that right? Or maybe they are connected together at the preamp ground screw?
I guess what I'm getting at is that one of these ground/shields is a problem. It may be that the cart lead shield is bad or the chassis ground is bad or they are connected together when they shouldn't be, or they need to be connected together. It could also be that the lugs are not making good contact where they are screwed in.
This all just a guess on my part, but hopefully it will give you some idea of what needs to be looked at. Just try different things with the grounding/shielding to see what the results are.
Bill
Previous Topic: Turntable is Skipping w/ White Noise
Next Topic: Is the sound quality of digital really as good as analoge?
Current Time: Sat Oct 24 23:35:05 CDT 2026
