Home » Audio » Source » Thorens TD-150 hum
Re: Ground or bad connection [message #13198 is a reply to message #13195] Thu, 07 December 2006 20:52 Go to previous messageGo to previous message
shoeihell is currently offline  shoeihell
OK, there is the base of the tonearm tube...(where the tube is screwed to the part that pivots, like a 'base'). There is a spade there that is attached to the pivot base, goes into the tonearm tube and then down the vertical shaft with the tonearm wires, comes out and is screwed to the metal table base with another spade/screw. The other ground goes from the terminal board of the cart shielded leads/RCA shielded leads to the receiver lug ground, via a 20ga solid core wire-that's easy enough to change to another type of wire if deemed too small or wrong type.
Previous Topic: Turntable is Skipping w/ White Noise
Next Topic: Is the sound quality of digital really as good as analoge?
Current Time: Thu Nov 05 02:26:53 CST 2026
