Home » Audio » Source » Thorens TD-150 hum
Re: Ground or bad connection [message #13195 is a reply to message #13193] Wed, 06 December 2006 19:30 Go to previous messageGo to previous message
Bill Agee is currently offline  Bill Agee
Where exactly does that ground wire connect to the tonearm? It may be that it has come loose fron the arm.
Try this: Remove the tonearm ground connection from the chassis where it is connected with the screw. How has the noise changed now?
Use another piece of wire, just for a test, and temporarily connect it from the tonearm to the chassis. How has the noise changed now?
Bill
Previous Topic: Turntable is Skipping w/ White Noise
Next Topic: Is the sound quality of digital really as good as analoge?
Current Time: Sat Oct 24 23:36:03 CDT 2026
