Home » Audio » Source » Thorens TD-150 hum
Re: Ground or bad connection [message #13190 is a reply to message #13189] Tue, 05 December 2006 15:00 Go to previous messageGo to previous message
When I say, "lifted the ground connection," I mean that it was probably made open or nearly open. If the ground connection is soldered to a spade lug that is tightened to the chassis with a screw, make sure the mechanical connection between lug and chassis is clean. Something has probably made the ground connection less effective. Check also to see that your signal wires are not run near the motor or power lines.
Previous Topic: Turntable is Skipping w/ White Noise
Next Topic: Is the sound quality of digital really as good as analoge?
Current Time: Thu Nov 05 02:26:51 CST 2026
