Home » Audio » Source » Sony Turntable Loud Hum
Re: Sony Turntable Loud Hum [message #13105 is a reply to message #13104] Sun, 08 October 2006 17:06 Go to previous messageGo to previous message
Shane M. is currently offline  Shane M.
Thanks for the reply. Hum is from both channels however, the hum stops when i remove the holder/cartrige from the end of the arm. So i swapped out the cartrige with an older one and the hum is back, so i ruled out a bad cart unless both are bad. I am going to try to replace both RCA cables to see if thats it. There is no grnd wire, is this normal? Thanks again.
Previous Topic: Whatever happened to MiniDiscs?
Next Topic: Garrard 440M manuals
Current Time: Thu Nov 05 22:53:15 CST 2026
