Home » Audio » Source » turntable buzz (grounding)
Re: turntable buzz (grounding) [message #13091 is a reply to message #13090] Sat, 16 September 2006 21:16 Go to previous message
I really dont know if that motor is shielded or not...that is one cause of hum with grados, but hum can be, as others have pointed out, from various different sources. Have you previously sucessfully used grados with this set up? Of course, of all components, phonos can be the worst hum problems, lots of gain on small signals, what is this turned up you are talking about? are you listening through headphones? Using a headphone amp for a pre or what? As gain is increased, hum generally will worsen if present. My mains are Altec A7s, well over 100db efficient, so hum MUST be kept to a minimum to be tolerable to say the least. Have any other cartridges to use to determine if it makes a difference?
Russellc
Previous Topic: Magnepa Unitrac I Tonearm kicks Arse!
Next Topic: Bang & Olufsen TT
Current Time: Thu Nov 05 04:44:52 CST 2026
