Home » Audio » Source » turntable buzz (grounding)
Re: turntable buzz (grounding) [message #13081 is a reply to message #13080] Sun, 10 September 2006 18:13 Go to previous messageGo to previous message
You always hear about "Grado hum" and unshielded TT motors are a problem.
But you describe static, not AC hum.
ISTM that what you have is the need to change the grounding set-up of table, cartridge and arm.
Is the table grounded or are you only using the ground on the cables?
Add a ground from table chassis to either the phono ground or another component.
The beatings will continue until morale improves
Previous Topic: Magnepa Unitrac I Tonearm kicks Arse!
Next Topic: Bang & Olufsen TT
Current Time: Thu Nov 05 08:19:18 CST 2026
