Home » Audio » Source » very low volume comes from the turntable
Re: very low volume comes from the turntable [message #13026 is a reply to message #13025] Sat, 29 July 2006 10:18 Go to previous message
Tre' is currently offline  Tre'
A phono cartridge output voltage is very low. The music cut into the grooves of a record is lacking in the bass and boosted in the treble. A phono pre-amp boosts the bass and cuts the treble and provides a lot of gain.
I took a look at the mixer you use and it has 3 phono inputs, that is three channels of phono pre-amplifiers.
http://www.soundandlightcity.co.za/DJ%20Mixers.htm
Your turntables should only work when pluged into the "phono" inputs on the mixer.
If one of your turntables worked and now it doesn't, I would think there is a connection problem with that turntable.
Sorry I couldn't help more.
Tre'
Previous Topic: Thank You Wayne!
Next Topic: Denon DP-51F - Can't keep tonearm on platter
Current Time: Thu Nov 05 22:59:56 CST 2026
