Home » Audio » Source » Thank You Wayne!
Re: warranty [message #13015 is a reply to message #13013] Sun, 23 July 2006 14:41 Go to previous messageGo to previous message
O'Kay but I will say that once it is built it becomes more difficult to add and change things. Not that it can't be done safely but It is little more involved.
This phono stage needs a good cart up front; it rises to the level of the input and will sound very much better the better stuff you use. If I may I think for the cheaper carts; AT is the best bet. 60$ ought to get you there.
Previous Topic: Crossfader question
Next Topic: very low volume comes from the turntable
Current Time: Thu Nov 05 22:23:01 CST 2026
