Home » Audio » Source » Thank You Wayne!
Re: warranty [message #13012 is a reply to message #13011] Sun, 23 July 2006 10:42 Go to previous messageGo to previous message
The Auto touch-up paint is what I used. I sprayed it after a thorough cleaning with alchohol and a chamois cloth. First I primed it then did three coats of the touch up paint in a nice beige color that matches the ashwood case really nicely. The paint has held up well three yrs so far. Other than that I did the tweaks on the Bottlehead site and it just plays along with any problems so far. In a nod to Wayne it does have a slight noticeable hum; although when I sit twelve feet back I can'tr hear it at my listening level.
I would build it soon in case there is a problem. You never know if a trans might be bad; it happens. And the boards can have a problem although it is very rare.
Previous Topic: Crossfader question
Next Topic: very low volume comes from the turntable
Current Time: Thu Nov 05 22:23:17 CST 2026
