Home » Audio » Source » New Turntable Advice
Re: New Turntable Advice [message #12916 is a reply to message #12907] Wed, 07 June 2006 13:27 Go to previous message
charlieboy is currently offline  charlieboy
Hi Chris,
Well as far as a table a good used Rega or Thorens would be nice. You can find the Regas with the 250 arm all day long. Cartridges would depend on if you want MM or MC. You can also find great used Musical Fidelty gear as far a inexpensive phono stage that will handle MM and MC in the older XLP model. I bought one for around 125 dollars a while back. Maybe the technics has a phono stage and you could mount the Staton on the rega for now. If your into vinyl The table and arm combo would be very important.Here's a Thorens 160BMKII that I have with an Ortofon cart and Rega arm. I have around 600 in it but it's a great table. You can find a more stock version of this for FAR less than I have in mine.
Previous Topic: Tascam 80-8 problem
Next Topic: Noise during playback
Current Time: Mon Oct 26 07:37:21 CDT 2026
