Home » Audio » Source » Technics 1200 Output Problem
Re: Technics 1200 Output Problem [message #12885 is a reply to message #12884] Tue, 09 May 2006 06:17 Go to previous messageGo to previous message
Probably loose cartridge pins. It's pretty rare that wire inside the arm is defective. But think of this; if you are getting continuity from the table to the RCA plug then the signal should be getting through. At this point there is not much that you can check on the table; try checking the continuitynfrom the cartridge pins to the RCA plug one at a time.
Previous Topic: DN990r md recorder error codes on used gear?
Next Topic: Numark mixer cuts out after every track
Current Time: Thu Nov 05 12:57:32 CST 2026
