Home » Audio » Source » Cartridge
Re: Cartridge [message #12877 is a reply to message #12679] Fri, 28 April 2006 00:48 Go to previous message
KARL VEE is currently offline  KARL VEE
Your answer is YES, a moving coil is that much better. Keep in mind not only the higher cost of the cartridge but you may also require a Pre-Pre amp or transformer. Some of the moving coil cartridges have a lower output and require this step-up unit unless your amp has an input for moving coil. Another factor, some cartridges must be returned to the factory for stylus replacement.
Previous Topic: Thorens TD 105 - HELP!!!!!!!!!
Next Topic: Turntable "skipping" - Help!
Current Time: Wed Nov 04 17:33:39 CST 2026
