Home » Audio » Source » Elac Miracord 50 H II
Elac Miracord 50 H II [message #12811] Tue, 21 February 2006 12:56 Go to previous message
draudio2u is currently offline  draudio2u
Greetings,
I have an ELAC 50 H II that I am trying to get working correctly. The problem is the automatic drop into the play position. The arm moves into place, the release lever moves down and then two seconds later, the arm drops by weight of gravity, bouncing the needle on the LP and into the first track. Is there not a counter spring to lower the arm slowly? Anyone have advice?
Thank you.
Previous Topic: broken needle
Next Topic: How important is a pre-amp if your amp has volume pots?
Current Time: Tue Oct 20 19:08:51 CDT 2026
