Home » Audio » Source » Any thoughts on a Denon DP-2000?
Re: Any thoughts on a Denon DP-2000? [message #12786 is a reply to message #12784] Mon, 13 February 2006 08:00 Go to previous messageGo to previous message
Man; you have decent sound! Thats a nice Vintage system that probably plays music better than 95% of everything else out there.
There are; as I see it some good choices you could make if your budget is tight. You could try an older table like a Thorens with the crappy Thorens arm for now.
I like all of the 1600/1700/1800 Technics tables because they have the good arm and are built like tanks, very speed stable and troublefree. And they sound pretty good. You can get them off E-Bay for 150$ usually with a decent cartridge. They retain their re-sale value also.
If you wish to go new; the Rega is a good table but after paying full price you may hit the 450$ mark. And truthfully; the least expensive Rega probably doesn't sound any better than the Technics does. Maybe worse with worse wow and flutter specs.
Previous Topic: Manualblock
Next Topic: broken needle
Current Time: Fri Nov 06 04:15:56 CST 2026
