Home » Audio » Source » Garrard 401
Re: Garrard 401 [message #12704 is a reply to message #12703] Sat, 07 January 2006 06:34 Go to previous messageGo to previous message
A lead with 2 flat pins sounds like the AC chord?
If so, then you need to look under the table to the base of the SME arm and find either RCA or DIN inputs for the cable that connects to the phono pre-amp.
On the top base of the arm there should be a plate that has the SME model number. Refer to the SME website. Also the Vinyl Engine and The Analog Dep't. SME has PDF files to cover the manual for your arm as well as many repair questions. Flat Earth Audio has parts in the U.S.
Congratulations! Your friend gave you about $1000 in equipment.
Previous Topic: Static Balanced auto flywheel as platter for DIY TT
Next Topic: annoying problems
Current Time: Sun Nov 22 22:38:19 CST 2026
